Microwave fuse blowing
Old 12-26-20, 07:01 AM
H
Moderator's note: separated from the following thread: GE Over the Range Microwave 20 Amp fuse keeps blowing up
Hello all; I have GE microwave #JVM1540LN1CS; My inline 20A fuse keeps blowing with the door close pretty much as soon as I start the microwave; I did test for continuity on the 3 door switches; I have continuity on the top and bottom switch but not on the middle one with the microwave door closed. I just want to confirm there should continuity on the middle switch with the door closed. Can anyone please confirm that for me? Thanks.
Old 12-26-20, 09:32 AM
Received 4,147 Upvotes on 3,724 Posts
There are two operation switches and one safety switch. I don't have the manual so I can't tell you which switch is the safety switch but it needs to open when the door is closed and short when the door is open.
Old 12-26-20, 10:02 AM
28 - WB06X10676 latch assembly
29 - WB24X829 switch (operation)
30 - WB24X830 switch (monitor)
31 - WB06X10128 actuator
Old 01-07-21, 07:39 AM
A
I have a GE Profile microwave (PEB2060SM1SS) that is blowing the internal fuse. The fuse blows as soon as you hit the start button with the door closed. This unit has a large button on the front to press to open the door - there is no handle to pull open the door.
Should i be looking at door switches or is there another troubleshooting route i should go down?
Thanks
