Issues with replacement charcoal filter for GE Over the Range Micro
Hello! I’m hoping someone can help me with this.
I have a GE JNM3163RJ3SS Microwave mounted above my gas range. It was all installed by my builder back in 2019.
Ever since we started cooking we noticed grease getting on the cabinets above the microwave. I never thought anything of it, just made it a habit to wipe them down more frequently.
Feeling frustrated, I decided to look at the owners manual which referenced a charcoal filter that needed replaced after 6-12 months of use. I ordered a new one (model WB02X10943, based on my owners manual).
It arrived today and I noticed it doesn’t match what is currently in my microwave. The replacement is long and narrow, the old one is shorter and wider.
What I found odd was that the manual doesn’t match up. For instance it references removing screws to access the charcoal filter, but there were no screws that needed removing. Instead stamped in the cover was text that just said “slide left” and it removed. The picture in the manual of the filter matched my current setup though. But every time I search the part # for the replacement, it matches the longer and more narrow filter.
Something else I found odd was that air seemed to be coming out of the entire opening (not just where the existing charcoal filter is). Could that be why grease is ending up on my cabinets? Is air bypassing the old filter and I should have the new one (which almost seems to fit the whole space).
One other thing to note: I never received a paper copy of the manual for my microwave. The manual I have is from GE’s website (downloaded based on the serial # I registered for my warranty upon product registration). The cover matches the model info in the microwave door though.
Does anyone know if the charcoal re-circulation filter should cover the whole opening, or just part as I currently have? Existing filter setup with cover removed Replacement filter based on model # in owners manual Side by side of existing and replacement filter Charcoal filter kit # from owners manual Charcoal filter replacement # with instructions Cover of owners manual Replacement filter almost fills the whole opening Box with part #
Vax Mach Air upright vacuum cleaner not running. Checked voltage to the motor connections is ok and tested the motor runs ok when removed from the unit. Could the suppression capacitor be the cause of the problem? If not, what else?
I have a Braun Coffee grinder. It has worked well for years and now the blades are stuff and hard to turn. The motor just hums when we turn it on. I took it apart and oiled the shafts on both sides of the motor but the motor still turns very slow and hard. Did I do the right thing? What is the best way to fix the motor so it turns easily?
Thank you,
GB
