"Open ground" outlet
Old 07-30-00, 02:13 PM
Post
I have an outlet showing "open ground" with a plug in tester, but I opened up the outlet and the ground is connected to the green ground screw on the outlet. I reattached it just in case, but it still shows as "open ground". Anyone know what is going on here? Thanks!
Old 07-30-00, 04:26 PM
Post
Mpproc,
The condition that is causing your open ground may not necessarily be in that box.
At some point in that circuit your ground wire is separated from the equipment and/or the grounding conductor. If you can guesstimate which outlet is just previous to the one you have tested, you may find it also an open ground, or it could be that the wire leaving this box is not connected, thus causing the open ground in the next.
I am asuming you have a grounded system.
Old 07-31-00, 05:52 AM
Post
After getting similar readings on several new outlets (on new circuits) I tried my tester on several existing outlets. When some of those failed, I got out my VOM. All circuits were fine. I returned the tester.
