switches
Old 07-28-02, 04:52 PM
sonyvaio74
Question switches
this may be a stupid question but noone around can answer with a sure answer.
is there such a thing as a 220 volt switch othe than a breaker.
what i want is like a light switch but that has two line and two load post.
thanks
Old 07-28-02, 04:57 PM
HandyRon's Avatar
Yes there is such a thing. What type of load is it? The switch would be particular to the load.
Old 07-28-02, 06:38 PM
HandyRon's Avatar
Old 07-28-02, 08:10 PM
tonyi
You want a two pole single throw switch. Each side has two terminals. The top/bottom terminals on respective sides operate like seperate ordinary switches with a common handle.
They have other uses too, like switching two seperate branches at the same time.
