Doorbell transformer location
Old 08-07-00, 01:01 PM
Guest
Question
I am trying to get some idea as to where a builder would have installed the doorbell transformer. The house is approx 15 years old and I am replacing the doorbell and not sure where to look for the transformer. Any ideas.
8/7/00 12:59pm MST
Thanks to all that replyed. I found it located near the furnace in the basement. I would never had thought of that spot.
8/9/00 06:15am MST
[This message has been edited by DougW (edited August 09, 2000).]
Old 08-07-00, 01:36 PM
Guest
Cool
Attic? Basement? Crawlspace? Closet? Should be where it can be reached and where it can be plugged into or wired to power source. I don't think that it is supposed to built into a wall. Look for the small bell wires, and track it down. Good Luck!
Old 08-07-00, 06:08 PM
Guest
Post
hello doug,
another common place for the transformer is in the panel, or verry close.
Old 08-07-00, 06:09 PM
Guest
Talking
Believe it or not, I've even found one tucked in to the bottom of a breaker panel (it got relocated, pronto...).
Old 08-07-00, 07:25 PM
Guest
Post
In my area we install the chime transformer to the SSU (or switch) box located at the furnace. This provides a handy location for mounting, power, and for running the low-voltage wires, since there will be heating low-voltage wires run in this area, anyway.
