No Electric
No Electric
I used an air conditioner and a microwave at the same time. They are both on the same circuit. The microwave stopped working, as well as the air conditioner. The circuit breaker did not "pop". Other outlets on the circuit still work though. Why did the breaker not "pop" and whay do the other outlets still work - the microwave and air conditioner do not? I plugged them into another outlet and verified it was not the units themselves.
Three main possibilites: (1) You tripped a GFCI, (2) the high current caused a weak connection to fail, quite possibly a backstabbed receptacle connection, or (3) you really did trip the breaker (even though it doesn't visually look like it) and those other outlets are actually on a different circuit.
Everything still works? thats good. I have no idea why your breaker didn't flip. It sounds like it should have.
It be as easy as resetting a GFCI outlet. any chance you have one of those on that circuit?
By the way, I would make sure that your A/C runs on its own circuit with its own breaker in the future. It pulls a pretty hefty current, especially if it is a 120V air conditioner.
No Electric
I do not have a GFCI.
I have talked to a friend and he said the same thing about the dedicated circuit foir the AC - Definately my next project after solving this problem.
It could be a possibility that the other outlets are not really on the same circuit. The description on the legend in the panel is what lead me to believe other outlets on the same circuit are working - I have not actually verified.
Someone said I could have fried the recepticle - Is this a possibility?
Thanks for your responses!
You're probably right about not having a GFCI. However, I just thought I'd point out that we have had an astounding number of people who made the same assertion but later found out that they did have a GFCI hiding somewhere in their house.
Yes, you could have fried a receptacle. That's essentially another description of my point (2).
