lawnmower repair
Old 08-02-02, 07:12 AM
maureen016
lawnmower repair
have a 3.5hp mower which pushes all the oil out when trying to start it.i know little about these thing so need help.
Old 08-02-02, 07:18 AM
K
I don't think you will get much help in the "electrical" forum here. Perhaps the "small engines" forum?
Old 08-02-02, 07:22 AM
Maureen,,, I think you might be in the wrong forum,,, but while you are here,, look for a clogged crankcase vent. Probably is a tube that goes to the aircleaner from the crankcase.
Old 08-02-02, 05:17 PM
FREDDYG_001
maureen, Like sperry27 was saying sounds like your crankcase vent is clogged from the oil breaking down due to wrong type oil your using. Your oil fill tube cap should have it stamp right on the cap what type and or grade of oil to use. Seeing how that is a 2 cycle engine castro make a very good oil.
Fred
Old 08-02-02, 05:50 PM
I am not yanking your chain Freddy,,, but its a four stroke. Hence the crankcase oil.
Old 08-02-02, 08:57 PM
FREDDYG_001
sperry27, Wasn't sure if that engine had reed valves (two stroke) or steel valves (four stroke). A broken piston ring will also give you the same problem.
Fred
Old 08-03-02, 08:38 AM
yes, broken ring is a possibility as well as a hole in the piston. She should put her thumb over the spack plug hole and see if there is compression when the cord is pulled. Watch out for the coil wire. ha,,, I had a company owner standing over my shoulder being a pain when I was reparing a generator one time,, so I tell him to hold this wire while I give it a crank. I couldnt believe he did it,, Pow,, went back to his office and didnt see him for a couple days.
Old 08-03-02, 09:55 AM
Debbie Ann
Angry
Oh, MY GOODNESS sberry27 !!!!
That is horrible !!!! I cannot believe that anyone would do such a thing intentionally.
Old 08-03-02, 11:37 AM
FREDDYG_001
sperry27, We use to do the same thing with ignition condensers.
Fred
