Wiring Garage
Getting ready to bury some wires for my garage. Gonna run 10/3uf out to garage. Can I bury 2 lengths of 10/3 and a length of 12/3 all in the same trench? I'm putting in one 220 20 amp outlet with one line, then a subpanel for lights and outlets with the other line. 12/3 is for three way switch for outside lights to be turned on from house or garage. Also can I put all these in 2" conduit to make it easier for future changes? If so can I run a phone line in the same conduit as the electric wires? The wire in the conduit would still be uf wire because I already bought it. Thanks for the help!
[This message has been edited by Magoo (edited August 13, 2000).]
Do not put the phone line in the same conduit as the power.
Because of the number of branch circuits you are running to the garage, you are required to install a disconnect, and a grounding electrode, at the garage.
I have a better idea, why not run a 50amp circuit out to garage, install the same sub-panel, and run your branch circuits out of this? You could still run your 3-wire for your 3-way switches, as the switches qualify as a disconnect.
If you don't follow this, get ahold of a DIY book at your local lumber yard, or ask an electrician.
Hope this helps. RM
Hope this helps. RM
