circut breaker
Old 08-04-02, 07:31 PM
banditowner
circut breaker
i hve replaced circut breakers in my main pannel with no trouble,my question is at my brothers house his has a breaker that keepes kicking off,he has one of these protable battery packs that you charge and carry in your car for emergencys i understand that it drawing to much for the breaker and also there are other things on the same plug,there is a space there with no breaker there extra space if i was to run a separate outlet no problem there ,now how do i do the wiring from the new outlet and connect in the fuse box. thanks
Old 08-04-02, 07:56 PM
What other things are on that circuit. That portable battery pack uses minimal current to charge. Something else is doing that. Read the label on te charger and it will tell the current input,, write back with that.
