electrical
I need help A.S.A.P in creating a wall plug from existing lite switch that only have two (black) hot wires.
Thank You
Thank You
You want to replace this light switch with a receptacle? If so, how are you going to switch the light?
If there are two black wires in this box and no other wires of any kind, then this is impossible. Post back and give us a complete inventory of all wires in the switch box, including wires tucked behind the switch and not connected to it. Be sure to turn off the breaker before making this investigation, and be careful not to disconnect anything.
dog, you need a nuetral wire to make that outlet work.
you do not have this wire in your switch box.
Is there anywhere else you can tap power from?
It needs to be a complete circiut, a hot wire and a nuetral wire.
Or you can run a new line from the panel.
How about a outlet on the other side of the wall, mabye?
Post back with more info on the layout of the room you are in.
Thank you
Thank you
The three of us have all told you this is not possible. You still want to do it (if it is possible). It is not. The best bet for you is to first understand how a switch works and what is needed for it to work. I strongly sugest you go to your local home improvment center and buy a DIYer book on home wiring. (15bucks?) they have alot of great pics, and explainations.
Start here first and you will quickly understand why this will not work.
good luck
good luck
Sam, all of us have asked you if there are any other wires in this box other than the two black wires connected to the switch. You have not directly answered that question. Have you pulled the switch out of the box and looked behind it? Is there anything there?
We're trying hard to find a way for this to work.
However, if there are no other wires behind it, then your two black wires are a hot and a switched hot. You have no path for the current to return to the panel. You need a complete circuit, and two black wires at a switch isn't enough. The best you could do is wire the receptacle in series with the light. If you did that, the light would not come on unless whatever was plugged into the receptacle was also on, and neither would function properly.
John,
I agree with everything you said to him but this:
This is not a good thing to tell someone who is trying hard to find a way to make this work.
As for the power at the switch,You still have no grounding conductor at the switch to take to your plug. Therefore
your plug will not work! If I am understanding you, there is two black wires on the switch. If this is an older house it is possible. If this house was built in the 70's you will not have just 2 black wires without any white wires. I don't know what else to tell you other than call an electrician!!
