3-way switch
Old 08-24-00, 05:46 AM
Guest
Question
We installed a dimmer switch to our dining room light. We didn't know this was a 3 way switch until we discovered that another light switch on the same circuit didn't work unless the new switch was turned off. We need to have the dimmer switch be a normal switch, just controlling the dining room light. Is there a way to turn the 3 way switch into a normal switch or do we have to buy a new non-3-way dimmer switch? Thanks.
Old 08-24-00, 07:02 AM
Guest
Post
Sure, use the common and one of the traveller
terminals/wires as you would a single switch, and leave the other traveller
disconnected, capped if it is a wire.
Old 08-24-00, 07:53 AM
Guest
Post
Gary is correct, but of course this isn't all you need to know. I think your problems with the other light switch is that you wired the feed-through power to the second traveller. So when you disconnect this second traveller (i.e., the second brass screw), be sure to reconnect it to the line side hot wire (using a pig-tail), to which it was probably connected before you installed the dimmer.
To do all this right, you'll need to figure out the purpose of all three black wires in your box: the line, the load, and the switched power. If you have no other way, you can do this by experimentation.
Good luck, and don't kill yourself.
Old 08-24-00, 09:14 PM
Guest
Post
It seems like I remember installing a dimmer that is a three-way switch. Check your electrical supply houses, maybe there is a dimmer that will work.
RM
Old 08-26-00, 03:13 PM
Guest
Post
hello vlc,
why not simply install a 3 way dimmer? they dont cost much more then a singel. this is what i recomend u do.
