Lights Dim When A/C Comes On
Our house was built in 1965. Sometime later (don't know when) an A/C system was installed. Now every time the A/C comes on, all the lights flicker for about a second. Could this be a bad sign? Do I need to do something?
hello will,
there could be several things going on here.
1. a loose connection(panel or ac circuit)
2. a service that is close to max size
3. unbalanced load.
whin a motor starts ther is a large amount of current draw for a fraction of a sec, this could be the cause of your problem if the panel is unbalanced.
3. unbalanced load.
