removing dimmer switch
Old 08-30-00, 10:33 AM
Question
I know this is probably very simple but for the life of me can't figure it out. I am painting our room and need to remove switch plate cover on a dimmer switch and cannot figure out how to get the "darn" round knob off??? Please help. Thank you
Old 08-30-00, 11:38 AM
Post
first off the only stupid question is one that is not ask. Evryone else wants to know how to do this to and just wouldn't ask turn the knob real slow and loking down on it see if there is a small hole for a screw to be in or look right at the front of it and see if there is a hole in front or gently turn it all the way counterclockwise and then see if it just unscrews from it or last gently pry on 2 sides of it at same time and see if it will slide off,know there are a lot of options but there is no way of knowing on your switch for sure
