electrical wiring 220 v dryer line/outlet
Old 09-03-00, 12:49 PM
Question
to accomdatethe purcahse of a new exletriv dryer. I believe, I need to install a new 30 amp/ 220v line from the panel to the dryer. There is a 110 outlet nearby can that be converted ? The panel is close to the the dryer so installing the new line would not create major access difficulty. How do i install 220 v line and outlet and what materials do I need (breaker type/wire size/ junction box/outlet type)
your help is appreciated
Old 09-03-00, 02:53 PM
Post
You need a 30 amp double pole breaker to fit your main panel, enough 10/3wg wire to run from main panel to plug location and a 4 wire 30 amp dryer plug. Buy a little extra wire - easy to cut off, hard to stretch.
