Adding a third 3-way switch
Old 09-05-00, 05:32 PM
Question
This is a new one to me. I've wired 3-way switches in the past that have consisted of the traditional two 3-way switches and any number of light fixtures. However, I have never needed more than 2 switches to control a light until now. So here it goes.
I've just moved into a new house and currently have 2 hallway lights and an entry light controlled by 2 3-way switches. One at the front door and the other in the master bedroom. What I want to do is add a 3rd switch in my back hallway to control these lights as well. How do I do this???
Do I simply add a 3-way to the loop or do I need to go to 4-way switches all around? If this is the case, then how do I wire it up? I currently have B,R,W & Ground. Assuming I need 4-way switches, will I need to completely rewire the circuit? And if so, what will the wiring scheme be?
Lastly, I want to remove the entry light from the loop so that it will be controlled by standard on/off switch. Do I simply disconnect all wires running to and from this fixture and wire nut them together in a juction box?
Thanks.
Old 09-05-00, 05:49 PM
Post
hello bulldawg13,
u would want to have 2 3way switches and 1 4 way switch for this. u need to remove 1 of the 3 ways (marking the travelers, wires on the gold screws, as well as the common wire on the black screw) and run 3 wire romex to new location from this box. in this box u want to connect the 2 existing travelers to the 4 way switch and your 2 new 1's to the 4 way, and wire nut the commons together stick with the same colors. in new switch location wire the 3 way exactily as it was removed from former location. im including several sites that deal with 3 way switches to hopfuly answer any ? u may have. http://www.howstuffworks.com/three-way.htm http://www.wfu.edu/~matthews/courses/p230/switches.html
Old 09-06-00, 06:51 AM
Post
another good site
<www.danselectricsupply.netfirms.com>
RM
