c
As far as how I'm going to take the wiring out, I'm going to use rigid conduit and go underground, then come up into a waterproof box next to the fountain. Any suggestions?
The maximum length of a circuit depends on two things:
the load current
the wire gauge
I suggest to search in this forumīs archives. You can find some related information.
On the other hand, I think you wonīt have problems with your application because household fountains use very small motors. Without knowing the details of the intended distance from the outlet to the fountain, I think you could safely use #12 AWG cable.
Good Luck!!
the load current
the wire gauge
Good Luck!!
Previous Thread
Next Thread
