once I remove the four bolts from my panel will anything
Old 08-24-02, 09:58 AM
C
Received 1 Upvote on 1 Post
fall out of the box? I know about electric.. Just wondering if once I take the 4 screws off holding the panel if anything will fall beside the door?
Old 08-24-02, 10:52 AM
MTgets
No.
Old 08-24-02, 04:47 PM
old_timer
this is a joke, right?....lol
Old 08-24-02, 09:40 PM
C
actually it was a serious question. I just want to make sure Im not overlooking something
Old 08-25-02, 07:16 AM
If you are not sure how to take the cover off what do you expect to do once you do remove it? What are you looking for?
Old 08-25-02, 08:51 AM
C
i just got to feed wires into the box.. I know there is three bus bars.. neutral, hot, ground
Old 08-25-02, 12:49 PM
MTgets
do you know there is 2 hot buss bars?
Old 08-25-02, 01:34 PM
C
i assume you saying since I have side by side breakers then their is 2 hots,1 neutral and 1 ground bar
Old 08-25-02, 03:21 PM
old_timer
caster, my friend, be very careful about what you think you know....... yes, there are 2 "hot" busses in your panel, and very well could be 3....the neutral, also. if you would explain exactly what you are planning to do in there, we will be glad to help you and guide you through the process. as far as anything "falling out", i have found mouse nests, mouse skeletons, mouse poop, etc. inside of these panels before. but, as far as electrical components falling out, the answer is "no", there shouldnt be anything in there that would "fall out".
sorry if it sounds as though we are making fun of you, because we're not. just very concerned that you may be attempting something that could be potentially disasterous for you.
please post back for any help that we can give you..
Old 08-25-02, 07:31 PM
C
what im doing is pulling 2 12ga circuits in. Also I want to put each on wire on its own breaker ( thats a given I think ) . Im just scared s**Tless of pulling this cover off the main panel. I got it in my head now that the main panel cover is like a switch cover. nothing going to happen unless I touch smothing inside.
Old 08-25-02, 08:05 PM
So far you are doing well,,, you have the right idea of putting the wires on their own breakers,, 20A ,,,, use connecters where the cable goes into the box.
