Range Problems
Range Problems
I recently wired my small cabin and am having troubles with the range. I ran 6-3 on a 50 Amp breaker and have 120 V. on each leg. The range will only heat up the broil coil on the top or the oven. The clock also works but nothing else will.
When I test for current the red leg draws 6 amps and the black draws nothing.
Any help is appreciated.
Thanks
Thanks
And check that you have 240v between the black and red. Perhaps you don't have 240v service, or perhaps both legs are on the same phase. Do you have any other 240v appliances in this cabin?
