wiring d box from double circuit breaker
Old 10-16-00, 04:02 PM
Post
Hi- I need info. We are having a submersible
deep well pump installed tomorrow and need to have it wired 220. We installed a double breaker in the panel box, but need to know
how to connect the wire from the breaker box to a safety shut off d box.
Old 10-16-00, 08:01 PM
Post
hello Charbarry,
follow these generac steps and u will be fine.if i had more info i could tell u exact steps, this is assuming u will be running uf wire and no conduit
1. turn off main breaker
2. remove panel cover
3. install 2 pole breaker in off position
4. run uf wire out of panel threw a romex clamp.
5. connect black and white of uf to breaker
6. connect bare of uf to ground bar
7. replace panel cover
8. turn main breaker back on
9. run wire to disconect
10. connect black and whit of uf to lugs of disconect
11. connect bare of uf to the disconect box useing a ground lug
12.your pump installer shuld wire from disconect to pump.
