GFCI usage in kitchen
Old 09-07-02, 06:00 PM
Thp1111
I'm doing my own electrical work in my kitchen, and I have a question about GFCI usage.
I know that my small appliance circuits should have a GFCI circuit, but which of the following appliances should have a GFCI outlet?
Refrigerator
Stove (gas w/electric ignitor)
Oven (240v)
Microwave
Dishwasher
Garbage Disposal
Stove Vent Hood
I heard once that a GFCI on a refrigerator is a pain because the startup of the compressor can trip the GFCI - but I want to follow code on this.
Any thoughts on this would be **greatly** appreciated.
Thanks,
Tony
Old 09-07-02, 06:47 PM
A
Master Electrician
Counter:
Hi Tony thanks for posting here:
The only thing in the kitchen that needs GFCI is the counter Recpt.
And you need at least two circuits for the counters.
Refrig's can be a problem, but mostly with the lower grade GFCI recpt. I have seen times lighting kicks them out, and if your not home it could be days before you find your food has went bad.
Old 09-07-02, 07:19 PM
Received 1 Upvote on 1 Post
I agree with Arthur. It is neither required nor typical nor advisable to put any of the appliances you mentioned on a GFCI.
