Electrical
Old 09-10-02, 09:09 AM
willsmith253
Electrical
I am wiring a new room. When I put the new plugs in how do i hook up the wiring from one plug to another, do I daisy chain and pig tail them? How how do i hook up the hot the the switches to bring power into the room?
Thank You
Will Smith
Old 09-10-02, 11:19 AM
G
You can daisy chain them in order to link them together and pigtailing the neurals will prevent the loss of downstream devices should you loose one device on the circuit. You should be careful not to overload the circuit though and if you do know what will be installed on a receptacle it is best to keep track of what it requires so you don't go over 16 amps on a twenty amp circuit.
It might be advisable to get yourself a good DIY book and read up a little before attempting anything if you are not familar with doing it, at least that way you can have a general idea on the codes involved so you don't have to redo it after the inspector sees it.
You might want to check out www.electricanpage.com seems to have a good deal of information you could use.
Old 09-10-02, 11:23 AM
willsmith253
Gard thatnk you for the response, I tried the URL you send but according to google it doesn't exsit, do you have it typed correctly
thanks
Will
Old 09-10-02, 01:26 PM
texsparky
Where did you bring the circuit from the panel?Does it go to the receptacles,the ligt fixture j-box,or to the switch box?Let us know a little more detail on how the wire is ran in this room.
Old 09-10-02, 01:40 PM
G
sorry spelled wrong so much easier when I could copy and paste
www.electricianpages.com
hopefully I got it that time
