Outdoor outlet has no power
Outdoor outlet has no power. It was working one minute and then it didn't. No CB's were tripped, I checked what I thought was the same circuit it's on, and that circuit is OK. (The box isn't very well labelled.)Every single other outlet and light in the house and garage are working. I pulled out the bad outlet, thinking that was the problem, but I tested the wires themselves and it showed no voltage at all. Now what could be wrong? A loose connector deep inside my walls? Please help, I am really stymied!!
Oldguy is probabaly correct. Look for the GFCI receptacle in any of the following locations: Garage, kitchen, bathrooms, or other outside outlets. It will be a special faced type, with a test and a reset button on it's face. If the reset button won't stay in when pressed, you may have a bod GFCI, which can be replaced fairly easy. Just follow the directions that are included with the new receptacle.
Good luck. RM
Good luck. RM
