reverse elec motor
Old 09-12-02, 08:07 PM
tedn333
reverse elec motor
Trying to reverse shaft rotation on 1hp elec single phase motor. I can read the schematic on the frame but not the numbers on the wires. Any help?
Old 09-12-02, 08:51 PM
Gary Tait
Their should be printed on the wires markings similar to what is on the schematic (on the motors I work with, the start
winding is marked T5 and T*, which you swap to reverse direction).
If nothing is marked, mark everything, and where it is connected,
disconnect everything, and test continuity of each wire to each other (using a DC continuity tester). Each run winding will have continuity to itself. The start winding will not have continuity, on account of the capacitor not conducting DC.
Old 09-13-02, 12:51 PM
P
Can the motor wired for either 110 or 220?---Do you have "loose" leads or threaded terminals studs for the line connections?
Old 09-13-02, 05:57 PM
tedn333
Gary Tait's reply did it. Checked the resistance and found start winding wires, switched them and the motor changed directions. Thanks for the help.
