USEFUL LINKS *No questions or advertising*
Old 09-20-02, 04:24 PM
Master Electrician
Arrow USEFUL LINKS *No questions or advertising*
http://home.c2i.net/dhb/firetop.htm - Dead link
Old 09-20-02, 06:43 PM
Master Electrician
Post useful Electrical sites here:
DIY'S Electrical & Lighting and Much Much More*****
Plus Telephone, Batteries, Electronics & Accessories:
http://doityourself.com/store/electricalandlighting.htm
http://www.doityourself.com/electric/index.htm ***
Home wiring, Pools, Garages, Much Much more *****
http://www.homewiringandmore.com/
homewiringusa/2002/index.html
Remote switches, And other neat stuff.*****
http://www.smarthome.com
National Electrical Code Author ***
http://www.nfpa.org/Home/index.asp
Learn to be an Electrician *****
http://www.code-electrical.com/
Underwriters Laboratories Inc. (UL) ***
http://www.ul.com/
Tricks of the trade ***
http://www.elec-toolbox.com/tricks/tricks.htm
Pictures of Violations *****
http://www.elec-toolbox.com/Pics/elecpics.htm/
Kids Safety, Electrical ******
http://www.smud.org/safety/world/site_files/
Electrical Safety ******
http://www.nesf.org/
http://esfi.org/home/
Outdoor Wiring****
[url]http://www.acehardware.com/PRC/ProjectKD/
electric/outlight/outlight.asp[url]
Register to be a member on DIY.com *****
http://forum.doityourself.com/regist...&action=signup
Aluminum wiring*****
http://www.inspect-ny.com/aluminum.htm
Product Manufacturers Web Pages: 905 Pages Here*****
http://doityourself.com/store/sortbymanufacturer.htm
DoItYourself.com Is In The Media*****
http://doityourself.com/media/index.htm
http://www.ecmweb.com/about/
Old 01-15-03, 08:54 AM
Honeywell "Online" Catolog
http://customer.honeywell.com
Old 07-06-03, 06:38 PM
Acdmx77
Thumbs up very helpful site
www.handymanwire.com
Old 07-10-03, 05:49 PM
texsparky
Post How to figure the cost of electricity
cost of energy
The cost of energy is found by applying the formula;
Cost=T xW x Cost/kWh divided by 1000
where
Cost=price (in dollars and cents)
T = time(in hours)
W = watts
Cost/kWh =price/kWh
1000=constant
Example....What is the cost for operating a 200 watt lamp for 24 hrs. if the utility charges 13 cents per kWh?
Cost = 24(hrs) x 200(watts) x .13(cents kWh) divided by 1000 =.62
Cost = 62 cents
Your cost per kWh will be found on your electric bill
To find watts when amps are known......amps x volts =watts
Old 11-14-03, 04:04 PM
Speedy Petey's Avatar
Old 07-30-04, 01:58 PM
sk545
ftp://rtfm.mit.edu/pub/usenet/news.a...trical-wiring/
electrical FAQ by someone at newsgroups.
Old 11-19-04, 11:38 AM
choo
Cool Old Wiring (with pictures)
This includes pictures of 3 types of old wiring (pre-Romex)
http://www.thisoldhouse.com/toh/know...98-12,00.html#
- "Knob and Tube"
- "Armored Cable"
- "Two-wire plastic sheathed Cable"
There are also links on the site to common wiring problems in older houses.
Old 11-30-04, 07:25 AM
ka3vvv
mikeholt
http://www.mikeholt.com/index.php?id=homegeneral
This good for NEC testing in a lot more.
You can take a test on line.
Old 11-30-04, 07:27 AM
ka3vvv
electricianeducation for beginner
http://www.electricianeducation.com/...hyperlinks.htm
He have good iformation on line and also in his book.
Old 12-14-04, 12:52 PM
bulldog88
Electrical Training
Journeyman/Master Electrician Training, Electrical Wiring (R & C), NFPA (NEC 2005, 2002, 1999), ICC (Building Codes), Blueprint Reading, Code Reference/Training, Electricity for HVAC, and Exam Prep...
http://www.delmarelectric.com
Old 01-02-06, 10:16 AM
HandyRon's Avatar
National Electric Code 2005
Go to the website below. Go toward the bottom for "Preview this document", choose "I agree", then choose "Open National Electrical CodeŽ Softbound 2005 Edition (NFPA 70)."
http://www.nfpa.org/aboutthecodes/Ab....asp?DocNum=70
Old 02-05-06, 11:27 AM
Old 03-23-06, 01:06 PM
Post
This site has a nice listing of the important codes the average DIY'er needs to know about wiring a home. It follows the 2005 NEC code.
http://www.howtowireahouse.com/
Old 04-16-06, 07:54 PM
pendoreilleskie
Idaho NEC application and exceptions
http://dbs.idaho.gov/electrical/nec.html
Idaho's application of NEC and exceptions
Old 06-20-06, 08:01 AM
Old 08-14-06, 07:50 PM
Oscilloscopes
All about oscilloscopes at http://www.xraygadgets.com
Old 09-11-06, 09:58 AM
http://electrical-contractor.net
Among the extensive information presented are Forums with photos of "nostalgic" electrical technology, and photos of incredibly bizarre violations, installations, etc.
Old 09-12-06, 08:16 AM
Changing a fuse in a fuse box
I know it sounds kind of lame but I've only just learned how to change the fuse in a fuse box. But I'm adamant that I can't be the only one who didn't know. Anyway I've also disciovered this link to a really clear demonstration and at the risk of looking like a spammer, here's the link. http://www.videojug.com/film/how-to-change-a-fuse-in-a-traditional-fuse-box.
Comment added by racraft
These directions are UK based, so don't attempt to apply these directly in North America!
Old 09-18-06, 06:05 PM
Smile Helpful hints for DIYrs'
1) DISCONNECT THE POWER before performing any work on these devices. TREAT the electricity with the respect it deserves. IT CAN KILL YOU.
2) when removing a light/Fan fixture-- Remove ONLY the wires connected to the existing fixture. This will make the re-install (nearly)fool proof.(even though they make better fools everyday).
3) When opening a Light/fan switch---DOCUMENT the location,color of each wire on the switch,BEFORE you disassemble it. Then draw it on paper (or other medium) for reference. Make note of the color of screws, if a three way or some other specialty switch.Identify the wires so you know where they came from and where they should go.
4)READ and understand the instructions that come with all devices.
5) Don't be afraid to admit you may be in over your head.
6) expect a few more questions from the respondants,This is how we find what you need to know.
7) Post back, so we know whether we have helped or not.
Many here spend alot of time trying to help you.
Just my thoughts.
Be SAFE. You only have you, and you can't replace your family. DO IT RIGHT.
Quote: jWhite:___Let me just add that trial and error is not the proper approach to electrical wiring. Leave trials to properly equipped testing laboratories.
Post questions in web forums, get books on electrical work, conduct web searchs for the required info, check with the equipment mfg about proper wireing methods, talk to knowledgeable people about the proper way, consult with your local building dept, etc.
And, when you go to do the work be sure you are doing it correctly.
____
BE SMART............BE SAFE !!!!
  #21
Old 07-26-08, 07:06 PM
Post do-it-yourself plug testing SAY NO TO THE PRO
http://thedomesticelectrician.webs.com
i used this site to learn to test recepticles myself
saved a couple of bucks every bit counts
  #22
Old 03-07-10, 11:12 AM
Trig Calculator
Trig Calculator very useful for adding vectors-
Trigonometry Calculator
  #23
Old 04-07-10, 11:40 PM
SilverTattoo's Avatar
Multibranch Wiring Circuits
Multibranch Wiring Circuits.
I found it to be a good read. Scroll down a little for article.
Electriciansparadise -- Multiwire Branch Circuits
  #24
Old 09-07-10, 08:52 PM
useful link
im glad to share my electrical engineering link,feel free to visit Sharing the knowledge
