Dimmer Switch
Old 09-28-02, 06:46 PM
buster69
Dimmer Switch
I am trying to install a 600 Watt single pole dimmer switch by Trade Master. It looks very simple. Just insert the ground into the ground terminal and the live wire into the backwire terminal. Unfortunetly when I do that the switch doesn't work. Is there something that I may be doing wrong? There are only 2 wires coming to that switch in the wall.
Old 09-28-02, 07:28 PM
HandyRon's Avatar
Are both of the wires insulated or is one of them bare?
Old 09-28-02, 07:36 PM
buster69
Dimmer Switch
Both are insulated. One is red and the other black.
Old 09-28-02, 08:09 PM
Received 1 Upvote on 1 Post
You don't have a ground wire. A dimmer switch will have three connections, two for the wires you have and one for the ground. Since you don't have a ground, use the other two connections.
Old 09-29-02, 08:36 AM
buster69
That worked. I guess I need to read up on home wiring before I do anything. I just assumed the black wire was the ground.
Thanks again for all of your help!
Old 09-29-02, 09:39 AM
One of the most dangerous things you can do is to connect a hot wire to a grounding connection. This is an electrocution waiting to happen. You are one extremely lucky person!!!
