water heater dillemma
Old 09-29-02, 09:14 PM
daloons5090
need to know where to put the wires i have romex with black red and white/ heater with black, blue, and yellow where do i put them
Old 09-29-02, 09:38 PM
Plumber2000's Avatar
Received 2 Upvotes on 2 Posts
These wires your trying to connect, you working with the stats under the access panels, or at the top of the heater?
Old 09-29-02, 09:42 PM
daloons5090
they are the stats that are in the "junction box" of the heater. my romex colors differ from the water heaters
Old 09-29-02, 09:44 PM
Why are you messing with the wires, what are you trying to do?
Old 09-29-02, 09:45 PM
daloons5090
install it, its a replacement tank
Old 09-29-02, 09:47 PM
The only wires you have to mess with on a replacement is the ones on top for the power supply, the ones in the panel are factory installed.
Old 09-29-02, 09:48 PM
daloons5090
srry those are the ones. that differ in color that i am trying to hook up
Old 09-29-02, 09:51 PM
Ok is this a 240 volt heater? You see the two wires comming from the heater, probably black and red right?
Old 09-29-02, 09:52 PM
daloons5090
i have blk/red/white/ground incoming.
from tank i have blk/blue/yellow....
Old 09-29-02, 09:57 PM
Three wires in-comming with a ground and three wires at top water heater access cover, never incountered a water heater needing that many wires for power, where do you live?
Old 09-29-02, 09:58 PM
daloons5090
akron, oh area,
its a kenmore tank
it is dual wattage too
Old 09-29-02, 10:01 PM
I'm going to move the thread to electrical forum they can help you there give it a minute to move and they will help you there.
Old 09-29-02, 10:02 PM
daloons5090
thanks
Old 09-29-02, 10:04 PM
Ok give them time to help here, I did not want to tell you to hook it up the wrong way.
Old 09-29-02, 10:21 PM
texsparky
What is meant by "dual wattage"?
Old 09-29-02, 10:25 PM
I don't know what he means, water heaters I install have just 2 wires, and suppy is 2 with the ground.
Old 09-30-02, 05:38 AM
HandyRon's Avatar
Some wacky colors. Was this purchased from oveseas?
Also, Do you have access to a install. manual or could you provide a link to the product you have from the manuaf. web site?
Old 09-30-02, 06:27 AM
Received 1 Upvote on 1 Post
Tell us what the installation instructions say about the electrical hookup.
Old 09-30-02, 07:44 AM
Are we sure that isnt a green wire???? Where does the blue one connect? Some people have hard time distinguishing between blue and green I know.
Old 09-30-02, 08:00 AM
The blue and yellow wire in usally found on the stats, you will find a black and red on the top of the heater, and the black and white are the power source, then there is the gounds, green or bare wire.
He talks of 4 wires for the power source. Never seen a source with four wires.
  #21
Old 09-30-02, 08:31 AM
Cap off the white on the source,,, you dont need it.
