Upgrading service questions!!!
Old 10-05-02, 04:32 PM
Termite
Question Upgrading service questions!!!
My wife and I are looking at a house, the inspector said that there is a 60 amp breaker that has a #10 wire and a #8 branch wire on it. In addition there is no room in panel to separate them. What would be our best choice in this situation? I know nothing about electrical work but want to know what my options are so we know if the electricians are being honest or if we may be able to do some of the work ourselfs. Thanks for any info.
Termite
Old 10-05-02, 04:46 PM
A
Master Electrician
Quad breaker:
Some panels will not except a quad breaker,If your panel does. It will take up the same space as the 60. and both wires will have thier own breaker. But I would suggest doing it with other breakers, like a 20/20, then install a 30 for #10, and a 40 for the #8
If this would work, it can cost less then 100 $
Old 10-05-02, 08:06 PM
Received 1 Upvote on 1 Post
As a condition of the purchase, ask the seller to have an electrician correct the problem and have it inspected by the city inspector and get a signed inspection certificate.
Old 10-05-02, 10:44 PM
bungalow jeff
Most insurance companies will not touch a house with 60A service.
Old 10-06-02, 01:26 AM
A
Master Electrician
John has raised a good point, but Jeff I donít think they meant they have a 60 amp service, only a 60 amp breaker with double wires in the terminals.
Old 10-06-02, 08:45 AM
Termite
Thanks for the replys, they have helped in pointing me in some direction! I do think that the current service is 100 amp, however I will check to make sure. Thanks again.
Termite
Old 10-06-02, 10:15 PM
bungalow jeff
Woops, not service, 60A breaker. At least in Northern NJ, 100A breaker is the minimum for the major insurance carriers.
Old 10-06-02, 10:17 PM
A
Master Electrician
Indiana as well, I believe this is becoming a standard set by insurance company's around the US.
