outlet removal
Old 10-16-02, 08:09 AM
pwestberg
Question outlet removal
How do I remove an unwanted outlet? It has one black and one white wire in it.
Old 10-16-02, 08:51 AM
texsparky
You will have to determine where the receptacle feeds from first.If the wire is in conduit,pull the wire out back to that point.If it is a cable (romex ,bx mc,etc)and cant be accessed for removal,disconnect the wire from where it feeds from and cut it loose.Remove as much of the abandoned wiring as you can.
Old 10-17-02, 07:54 AM
pwestberg
Done and plastered over. Thanks
