Upgrading my service panel ?'s
Hi -
I'm finishing the basement of my 6 year old house and I think I should upgrade the service. here's the specs: 1400 sq.ft. ranch, full basement. OE service panel is a 100A Cutler Hammer with about 5 slots left. All gas appliances, with central air.
I'm not looking for more than 3 additional circuits for the basement at this time, but there could be more.
Also, when my Central Air was installed, I think the contractor wired it right off the main. If I upgrade the panel, I'll get that fixed, for sure.
I can get a Cutler Hammer 200A contractors special package at Lowes. That way, I can re-use some of the breakers from the current panel.
My questions are:
should I upgrade?
If I do, is the 200A box above the right way to go?
What else do I need to consider? Meter rating? Wire size from the meter to the box? (I think it's AWG 1)
Thanks!
My questions are:
should I upgrade?
Thanks!
Square footage is only a small part of the equation--literally. I would suggest following the links below, reading thoroughly and then working out your demand load calculation. Wgoodrich's site helped me with this task and I found that my existing 150A service was more than adequate for my 1200 sf home with the only gas appliance being my water heater.
Wgoodrich's home wiring site:
www.homewiringandmore.com
General Method of Dwelling Calculation:
http://www.homewiringandmore.com/hom...DmdCalc02.html
Some additional helpful explanations can be found here:
http://www.homewiringandmore.com/hom...ter/meter.html (click on "Sizing your servic rated panel or main disconnect" on the left of that page)
Also see the thread on this forum I started called "Dwelling demand load calculation questions" (last post 05/29/02--you can do a search for posts that "Moonpie" has posted (I haven't posted that many)). That thread might answer questions you might have, like I did, after starting your calculations.
Best wishes!
Best wishes!
Received 0 Votes
Yes, doing a load calc is the right way. How heavy is the AC? With all gas you probably ok for now, but a service upgrade wont hurt anything and you would be finished for a while. I dont use a lot of Ch,, and might need to be corrected here, but there are 2 types,,, type BR I believe and type CH and I am sure they are not interchangable.
