help with bx cable
help with bx cable
Hi I would appreciate some info on how to cut the BX armor,i have been using a metal saw to cut on one of the ridges and bend the cable on the cut.
This leaves a sharp and uneven edge and hardely any room to sleep the antishort bushing to protect the wires .
Thank you very much for advice papi
There is a tool called a rotosplit (not to be confused with rotozip) that is made specifically for cutting armored cable.It's been awhile since I've bought one,but I think I paid around $25 for it.It was money well spent.
I think I have seen them at Home Depot in the electrical dept. and most electrical supply houses have them.
The way to cut the armor with a hacksaw is to cut as parrallel with the cable as you can (use a 32 teeth per inch blade to prevent binding) This takes a little practice,but I know some old-timers who prefer the hacksaw.
The tool is definately worth it! I paid 19.95 for mine and saves a considerable amount of hassle making sure the wire insulation isn't nicked by cutting into the armor with cutters.
With the tool it's a couple of quick turns of the handle and a quick snap of the armor and you're all set. The armor comes right off.
One other note, don't forget to put on a plastic bushing to make sure the wire doesn't get cut into buy the armor after it is cut.
Thank you all for help.it is really nice of you to share your knowledge and experiences with others even if some times there are desagriments. This is a great site///////
Regrds Papi
Regrds Papi
Originally posted by texsparky
bwetzl,although it might work,I doubt that is what the manufacturer would recommend as it sounds like a good way to damage the insulation on the wire.
Brian
