Replaced outlets but no power restored
I threw the circuit breaker to change out some old outlets. The circuit controlled 2 bedrooms and 2 bathrooms. After I replaced the outlets, I went to turn the power back on. Well, the power has not returned. Fortunately, the outside wall outlet in the bedroom I replaced the outlets in must be on another circuit because it works. The rest of the outlets and switches in both bedrooms and baths are out. The outlets are single-pole (2 white wires and 2 black wires with no ground). I've tried flipping the circuit breaker switch several times, but nothing happens. I even threw the main switch. Any suggestions? Thanks!!!!!
OK. I double checked the outlets I replaced. Everything appears to be fine. The bathroom outlets are not gfci. The one working outlet turns out to be on the same circuit as the rest that are not working. The one working outlet turns out to be on the same circuit as the rest that are not working. Ummmm.
Be sure all wall switches in and near the rooms where you replaced the devices are "On"---The next step is to expose the terminals of the devices you replaced for a positive voltage check across the wires. Check ALL combinations where 2 Blacks and 2 Whites connect to a receptacle---Black 1 to White 1 and White2, Black 2 to White 1 and White 2.--Did you replace receptacles only?---Good Luck!!
