Replacing old two-prong outlets
I am looking to replace the old two-prong outlets in my house with new standard grounded receptacles. The question I have is: Can I do this by installing the new grounded receptacles in the boxes and then run a bare copper ground wire from the new receptacle ground screw to the receptacle box??? Thanks in advance for any suggestions.
What kind of cable is running to the box in the first place? Would it be conduit or MC or Romax? MC and conduit would be grounded to the box but Romex would not so the answer would depend on what it is.
You could install GFCI's which the code allows as replacements when marked for no ground.
