can it be done
Old 11-03-02, 05:34 AM
tennessee
can it be done
can the electric companys,during mild winters decrease volts being sent to people so your hot water heater. heat pump, fridge,etc will work harder so more electric will be used= more profit. have a friend who works with company said this is done
Old 11-03-02, 05:56 AM
Mike Swearingen's Avatar
Received 1 Upvote on 1 Post
Cool
I have no idea if that is ever actually done, but after Enron's deliberate rate rape of California during it's energy crisis, nothing would surprise me.
Mike
Old 11-03-02, 06:11 AM
I
Reducing voltage actually has the opposite effect, especially for purely resistive loads like water heaters and electric stoves. It's the law. (Ohm's law)
Ichabod
Old 11-03-02, 07:19 AM
Received 500 Upvotes on 410 Posts
Voltage drops because of demand. It does not cause you to use more power. They are not dropping the voltage to cause you to pay a higher bill. There is no conspiracy.
Old 11-03-02, 09:15 AM
Right,, there has never been any conspiricy in the energy business,,, and never will be!!!
Old 11-03-02, 11:18 AM
hornetd's Avatar
Originally posted by sberry27
"Right,, there has never been any conspiricy in the energy business,,, and never will be!!!"
sberry27
If you understood Watt hour metering you would know that this particular tactic would no work. The meters are built by meter manufacturing companies rather than by power utilities. The meters measure the actual power delivered over time and any decrease in voltage causes the meter to register less power used rather than more.
Tom
Old 11-03-02, 03:35 PM
If you understood humor then you would know a joke when you heard one.
Old 11-03-02, 09:38 PM
bungalow jeff
I do know that Con Edison would tweak the distribution on hot summer days to avoid brown-outs by diverting power from commercial clients. This would knock out the tunnel boring machine used on the 3rd Water Tunnel Project in Queens for the rest of the day.
