wiring problems
Old 11-06-02, 12:59 PM
flye
wiring problems
my porch light quit working. put new switch in no luck. It feeds off a 3 way but it is a 2 way. Have meter what do i check?
Old 11-06-02, 01:21 PM
Received 1 Upvote on 1 Post
What does "It feeds off a 3 way but it is a 2 way" mean?
If you have a voltmeter, check for voltage at the light bulb socket. If none, then remove the light fixture and check for voltage at the two wires that were connected to the light. Consider tripped GFCI, tripped breaker, burnt out bulb.
Old 11-06-02, 01:33 PM
flye
there are 2 switches that controll a hall light. One hall switch and the porch light are in the same box next to the front door.
Old 11-06-02, 03:20 PM
flye
John, I tried the light fixture. That was the problem. Thank you for your help.
