Transformer.
Old 11-06-02, 04:50 PM
beverlyaris
Transformer.
Dear Sr.
I like you to tell me how do i connect a transformer 120v to 12v
the transformer has 2 connetions two wires mark black for 120v
and the other two mark yellow 12v.I also have a swicht to turn
on and off the three small lights that am going to put up on the ceiling,each light i think they are 12v each or 5v.
Please let me know how do I hook up all these wires, and thank
you very much in advance.
Yours truly
Old 11-06-02, 05:04 PM
fatkid66's Avatar
sounds to me like the black wires connect to your 120v supply, while the yellow wires are the feeds to your low voltage lights. it sounds like the switch is for the +12v side of the transformer and will be connected between the transformer and the first light.
does this help?
Old 11-06-02, 05:23 PM
beverlyaris
Transformer.
Dear Fatkid66
I am replying to your answer, I would like to know these, there is
only , or i only has two wires going to the transformer black hot wire and the white wire , does these go to the transfomer to connect to where it says black wires.
Waiting for your anwser and dont dance with the devil, you probably mean the new jersey devils.
Old 11-06-02, 05:43 PM
fatkid66's Avatar
sounds to me like the black and white will connect to the 2 black wires. black of 120v to 1 black trans. wire and the white 120v wire to the other black trans. wire.
hope that helps
