about transformer
about transformer
I have some questions about the transformer.
How to connect the transformer, what is the meaning about the symbol which ones on the terminal?
Thank for your help!
Is this a doorbell transformer? Or something else?
A typical doorbell transformer has two wires that are connected to a 120-volt supply. It has two screws that deliver a lower voltage, perhaps 12 or 16 or 24 volts.
Can you give us some more details of your project?
Hello,John Nelson
Thank you for your concern.
The transformer I talking about is the 3 phase 600 voltage to 3 phase 208 voltage one. I want to know the meaning about the terminal and how to connect the cable for it. Thank you for help.
One more thing, I heard that the neutral should be connect with the grounding in the 208v/110v, Is that right?
Received 0 Votes
The type of transformer your talking about is not something a homeowner or D-I-Yer will EVER run across. I suggest you hire an electrician for this one. I'll keep the knowledge I have about this to myself and my apprentices. This is NOT something a D-I-Yer should attempt
