converting 110 to 220.
i see the earlier question posted on going from 220 to 110. but i also see where you can buy converters that are labelled for continuous use. here's my problem. my garbage disposer died last week. i bought one off of ebay for half what the stores wanted. and with my luck, i noticed after the fact that it's 220. i'm at work, so i haven't had the chance to look, but i'm sure that my current disposer is 110.
can i get one of these "continuous use" converters? i've run wire for new circuits before, but hate going up in the attic.
thanks,
mitch
thanks,
mitch
No, that would not be practical. If the disposal is on its OWN circuit you can correct this,,, but if not you need a new circuit from the panel. The thing is probably European,, that might have some other problems I am not sure. I havnt seen residential disposals 240 v before. Sometimes the half price is not a bargain,, re sell it an buy the right one,, it probably be cheaper and easier. Or trash it and count as a lesson learned.
