Old home upgrade
Old 12-10-02, 08:25 PM
Gettinitdone
Old home upgrade
Just bought a 1956 1020 sq. ft. ranch. We upgraded the service to 200 amp with breakers from 60 amp with fuses and had GFCI's put in the kitchen and the bathroom.
I'd like to have a few new 20 amp circuits run for the kitchen, a couple in the dining room, 1 for the computer room. Can someone give me a ballpark cost for an electrician to run a new 20 amp circuit with wiring and outlet?
Virtually none of the outlets are grounded. What would it take to have the outlets grounded?
Bob
Old 12-11-02, 05:00 AM
RickJ6956
I recently got quoted $100 per drop including materials. A "drop" is a recep, switch, junction box, lighting box or connection to the panel. It was a ballpark quote, and he said that if I wanted two receps within a few feet of each other (kitchen, for example), it would be much cheaper than $100 for the additional drops.
The quote was for new construction and/or accessible wiring. Rewiring into existing construction was to be billed at time & materials.
Hope this helps ...
Old 12-11-02, 05:23 AM
Grounding the outlets will either require a separate ground wire (typically green) running from the outlet to the panel, or a short green wire connecting the outlet to the metal box, provided there is a run of metal conduit/boxes all the way back to the panel.
Not that difficult a thing for the DIY-er, but it does take a lot of time and patience.
Old 12-11-02, 05:55 AM
C
We paid about $100 per drop for rewiring our 1929 house.
Old 12-11-02, 12:57 PM
Gettinitdone
Cost for new drops
Wow, what part of the country are you guys from? Do you mean that if I have 2 new 20 amp circuits installed (breaker is already in the panel) wired, fished, new box, plug and face - it should cost me about $200?
Old 12-11-02, 04:49 PM
winkleal
Depending on the layout and accessability to the attic and basement, yes. This would be for one outlet.
Tony
Old 12-11-02, 09:58 PM
RickJ6956
Gettin,
It's the difference between DIYers and pros. Save about 50% or more by doing it yourself -- and be sure to figure the time.
Do you do it because you save money ? Or because you enjoy seeing the fruits of your labors?
Old 12-12-02, 05:13 AM
Gettinitdone
For both
Rick:
I do it for both the enjoyment of the accomplishment and the savings.
I got a quote from the contractor who did my 200 amp service upgrade and they will do the new circuits for $200 each.
Bob
