GFCI problem
GFCI problem
It usually isn't necessary to replace the GFCI. Resetting it usually works. Press the "R" button on all of them you can find. If that doesn't work, spring for $8 to buy a receptacle tester. Let us know what it says.
Re: GFCI problem
Well I figured out what the problem was, it seems a crawl space sump pump on the same circuit went out and that is what caused the problem. Once the pump was unplugged the circuit worked fine. Now off to the HD to buy a new pump.
