not sure what 2 do
Old 12-27-02, 04:31 PM
jamoke
not sure what 2 do
wasnt sure which forum to put this in either so if im in the wrong one please b easy on me im new:O)
anyway i am in the process of remodeling my bathroom and behid where the 1 piece shower/tub will be is all the wires for the breaker box that is outside.
what i would like to know what would be best to cover that wall
with. sheet rock or should it be something else cause of the electric?? thx in advance
Old 12-27-02, 04:38 PM
G
I would suggest a water proof material is the shower stall full sized to ensure the water won't get on the inner wall?
Old 12-27-02, 04:40 PM
Received 1 Upvote on 1 Post
There are no special consideration because of the wires. Bathroom walls are best covered with moisture-resistant drywall (aka greenboard), and painted with two coats of semigloss enamel. If the wall will actually get wet, use roofing felt, cement board and tile.
Old 12-27-02, 04:41 PM
jamoke
yes its a 5' bath/shower combo 1 piece no seams
so the only exposed part of the wall will be the top 2 feet
from top of shower to ceiling
thx for the fast reply u guys r great:O)
Old 12-27-02, 04:47 PM
jamoke
john nelson thx for the reply i was replying when u were so i didnt see it till i posted but wanted to thank you none the less
