Auto-Ground
Auto-Ground
Does the auto-ground connection on devices (switches & outlets) meet the NEC code?
In other words, do I REALLY need to connect a green wire from the gound screw on the device to the metal box?
My metal boxes are all grounded with the Romex ground.
I realize the device will only be grounded when installed in the metal box....but I would never be working on the box unless the feed was off anyway.
Bill
-Just want to do the right thing.
Bill
Some devices are tested and listed by UL (identified in the device instructions) to have their yolk (metal mounting part of the device) to act as a grounding means. Many devices are not listed this way and must have the ground screw from the yolk attached to the box.
Autoground
Ron,
Thanks for your response.
Still need to know if Code requires a seperate ground conductor connected to the device...or autoground is sufficient to compy.
Bill
Bill
