Loose breaker / now it wont turn on?
Old 01-06-03, 07:41 AM
C
In order to paint the ceiling in my kitchen, I needed to remove an old ceiling fan.
Long story short, when I went down to shut off breakers to figure out which one the fan/light was on, one of the breakers I touched was "loose" -- eg it moved away from what ever it is connected to one the bottom. I pushed it back down, but now it keeps tripping when I try to turn it on.
It is a 15 amp, normal width if this helps. It feeds power to the lights in a powder room and a dining room chandelier. (yes, not quite current code!)
A procedure to fix would be appreciated.
Old 01-06-03, 07:57 AM
T
You'll have to open the panel and see what the problem is. It's rare that a breaker would "desintegrate", I'm guessing that something got loose.
What type of breakers? What brand?
Old 01-06-03, 08:56 AM
Received 1 Upvote on 1 Post
Breakers that have tripped too many times are shot. Could even be the wrong breaker for the panel. In either case, it's probably time to replace it.
BTW, the situation you mention is not a code violation, even today's code.
Old 01-06-03, 09:14 AM
G
Curiousity on my part what manufacturer is the breaker and who made the panel?
Old 01-06-03, 10:22 AM
C
Thanks for the speedy replies guys!
AFAIK - the reason I thought I had a code issue was that the powder room is powered off this circuit (outlet, fan, and separate light) as well as the dining room chandelier.
I will post back with the brand of the panel box and breaker tonight after I go back and look at it. I had the cover off at the time I was shutting off the breaker if that makes any difference.
If I wanted to remove the breaker, the procedure would be to shut off the main 100A breaker and then pull out the offender and replace, right? Can I leave the space empty and turn on the power (then go to HD to buy a new breaker)
Thanks.
Old 01-06-03, 11:15 AM
Received 501 Upvotes on 411 Posts
You can leave the space empty. Put a wire nut on the wire to prevent it from touching anything in the panel. Put a piece of tape over the hole to anyone from poking something into the panel.
