Reload this Page >
3 way switch, multiple fixtures, dimmers, one circuit breaker
Old 01-07-03, 06:52 PM
Hello all. I'm hoping I may be able to get some answers here. This is my dilemma, I will describe it best I can. I'm putting a drop cieling in my basement along with recessed lighting. It will involve 3 way switches and dimmers. Here goes......I currently have a switch that controls a light at the top of my stairwell and a light in the basement. I want to move the light in the basement and add a switch in the basement so that the lights can be turned off/on from the basement. I'm not sure whether the power goes to the switch or the light. How can I find out? What would be the best route to take? I will also be adding 3 sets of lights, 2 sets controlled by dimmers, 1 set controlled with a single switch. Is it possible to put these all on the same circuit, and if so, how do I continue the power? If you need more info please don't hesitate to email me....Thank you very much...
Ron
Old 01-07-03, 07:02 PM
Received 1 Upvote on 1 Post
First, look in the switch box at the top of the stairs. Tell us everything you see: all the cables, all the wires, and all the connections (whether or not connected to the switch).
Most likely you will need to run a new 14/3 cable from the existing switch to where you want the new switch (no matter where the power comes in).
Yes, it's very easily possible to put all those on the same new circuit. If you're talking about adding to an existing circuit, you'll need to analyze what's already on that circuit now (but it's probably still okay).
How to do it depends on a lot of factors not in evidence. Are there any unswitched receptacles currently in that basement? Or are there a lot of cables running around on the ceiling? How many lights in a "set" and what wattage bulbs are we talking about? Are you also going to add any receptacles?
Old 01-07-03, 07:13 PM
John, just wanted to say WOW, that was quick, thanks. I will get back as soon as I have the answers to your questions......Time for bed now tho.........
Ron
