electrical wiring
electrical wiring
Thanks...reply to electical wiring questions
Thanks for the come back. The lights stay on continuously and do not flicker.
If the breaker is bad, do you now why some sockets and lights would work when the breaker is turned off and why others (in a different room but on the same circuit) would not work?
Thanks again
Thanks again
Hmmm. Missed that in the first post. Another breaker has to be "responsible" for the other outlet. Try flicking others off all the way and on again. Sometimes breakers trip but don't look like they have. It's also possible the outlet is downstream from a GFI, or is it a GFI itself?
Why this would have happened all at once is puzzling though. Could you have had a power surge?
