need to tap 220 for 110 leg.
Old 01-11-03, 11:41 AM
highkamp
I am wanting to tap (temporaily) a 220 line that currently feeds my well pump. I would like to connect at the toggle switch (220) and run a 110 leg to convert to a new switch/recept. combo outlet. Is this possible since the 2/12 feed to 220 switch has no spare neutral for the 110 receptical. Only two hots and a ground. Can the ground be used as the 110 neutral? (which normally your never supposed to do) But on a 220 2/12 is the ground the neutral but why is that allowed on 220 and not 110.
Thanks
Old 01-11-03, 11:51 AM
Received 1 Upvote on 1 Post
The ground could thoeretically be used for the neutral, but not legally, and not without a great compromise to safety. Don't do it!
The 220 needs no neutral. The two hots serve as the return path for each other. If there was a neutral in this cable, there would be no place to connect it at the pump, because the pump has no use for it.
Old 01-11-03, 12:14 PM
highkamp
Thanks, I suspected that might be the answer. I will just run a new 110 circuit and leave the 220 alone.
