Am I Using Electricity?
on an appliance plugged into an outlet even though it is not turned on? Need your expertise to clear this with a friend. Thanks.
The loads presented by off-but-still-on items are often referred to as 'phantom loads'. Anything with a built in remote control is always partly on. If the microwave has a touch panel it is always partly on. Anything with a clock that does not have a battery (and even some with a battery) is always partly on. Electronic thermostats pull power from the heater control circuit. The power used is normally very little, but it is there. A year is 8,760 hours. So a 1 watt load running for an entire year would use 8.76 kilowatt-hours. At 12 cents/kW-h you spend $1.05 per year to keep that 1 watt load runnning. More watts, more money.
