new outlets
Old 01-19-03, 11:16 AM
K
new outlets
I currently have two outlets behind my countertop, one to each side of the sink......there is 12-2 wiring to both, and both are on the same breaker....I would like to add an outlet on each side of the existing ones...is it ok to run the wires from the existing outlet boxes to the new ones...versus having to fish new wires up the wall from the basement????
Old 01-19-03, 12:29 PM
Kooter's Avatar
Received 88 Upvotes on 81 Posts
The assumption is that the reason you need the additional receptacles is because you anticipate having additional appliances (loads) requiring a place to plug them in. If this is true...it may be best that you run another circuit so you don't overload the existing circuit. However, if the reason you want to add additional receptacles is for convenience of their location then it is okay that you loop from the existing receptacles to feed the new receptacles.
Kooter
Old 01-19-03, 12:32 PM
P
Kitchen counter-top receptacles should be GFI protected,and you'd have much better results if the receptacles on the left side were on a 20 amp circuit seperate from the 20 amp circuit for the receptacles on the right side.You mention that the outlets "are behind the counter-top."----Does this mean that the outlet- boxes are behind the "back-splash", and that you will have to cut into the "back-splash" for additional outlet-boxes?-----Good Luck!!!!
Old 01-19-03, 12:36 PM
K
new outlets
no...!!!.....i won't have to cut into the back splash....they are on the wall above the backsplash, but I have that wall torn out....it was old plaster and I'm replacing it with drywall...and the reason I want a couple more outlets is just for convenience in respect to where I'm working on the countertop, not that I want to use more appliances and at one time.....
thanks to both of you for your help
Old 01-19-03, 03:41 PM
Received 1 Upvote on 1 Post
By all means, use the existing circuit. If you were to install another circuit, we'd have to give you a dozen more electrical codes to deal with. Just make sure you know how to properly GFCI protect them.
