I currently have two outlets behind my countertop, one to each side of the sink......there is 12-2 wiring to both, and both are on the same breaker....I would like to add an outlet on each side of the existing ones...is it ok to run the wires from the existing outlet boxes to the new ones...versus having to fish new wires up the wall from the basement????:confused:Read More
:confused: I am trying to wire a light system together. The lampholder is rated at 600v as is the wire. The wire attached to the male plug is 125v and the light is 120v. Will mixing these voltage ratings cause problems or is everything cool to wire?:confused:Read More
