special outlet plate
I have a wierd configuration for an outlet plate that I can't find pre-made........any ideas what I use to cut out a blank plastic plate with...with out breaking the darn thing???
thanks
thanks
outlet plate
Well, I know it's not "code", but I want an outlet (plug) and a cable tv "hole" beside it....
sound like something I can get at Home Depot???
There are some nifty modular cover plates at Home Depot. I recently had an application that I could not find a coverplate for anywhere and made my own. I need a 2-gang box covered with a plate that had a GFCI hole on one side and none on the other. I just bought a blank plate and cut out a hole using a air-driven die grinder and small cut off wheels. A dremel would work just as well. Good Luck.
Check your local electrical supply house. They should have a two gang duplex/blank plate available. Then merely drill a hole in the center the correct size for an "f" coupling. Clamp the cover upside-down on a piece of scrap wood. Drill slowly with a very sharp bit.
If anyone asks, I will deny helping you violate the code
The individual sections I described or the modular plates as described by BobMachus are the way to go. I think we are describing the same item.
As last option, do like Bolted Fault.
when i did this i used a single gang box (made a hole beside the box) then used a decora catv/phone plate then used a recptical makes a clean neat instal this is just what i did
catv jack
http://www.lowes.com/lkn?action=prod...00000334-2162A
catv/phone
http://www.lowes.com/lkn?action=prod...00000334-3562V
catv jack
catv/phone
