transformers england to usa
i am an immigrant to the usa with some 240v power tools and 240v rated extension cords . How can i adapt my 240v set-up to 120v conditions?
The "standard" residential electrical service in the USA is a 3-wire, 220/110 volt 60-cycle system which means you can connect circuits for either 220 volt or 110 volt operation. As for the performance of a 240 volt 50-cycle motor operating on a 220 volt 60-cycle circuit, much depends on the type of motor. If the motor operates without brushes it's an induction motor. If it's a brush-type then it's a "universal" motor that operates on both D.C. and A.C.---Good Luck!!!
